Idle issues
doors67us
Needle on the left is the original, other is the replacement
What is the status of item #35 , part of low speed circuit.----I do not see compression values posted here.
doors67us
I have cleaned everything in that carburetor thoroughly with carb spray carburetor brushes and Air I have it back together now with the original needle it runs better but doesn't idle smoothly as much as I'd like
davidmbv
Part 35 sometimes gets stuck inside the carb and could be damaged. If you haven’t already done so, inspect part 35 that little piece of plastic can get damaged or broken especially when soaking in carb cleaner etc.
other than that, try hooking it up to a timing light when running and make sure your not dropping a cylinder. I had a condenser wire that was damaged by the flywheel spinning and would intermittently short out . Drove me crazy until I noticed the small nick of exposed wire. Also I would stick with OMC fuel pumps. They are expensive but I’ve had issues using cheap aftermarket fuel pumps.
davidmbv
If all else fails, run a can of this stuff. It helped one I had issues with low idle. After I ran a can of tuner, it now idles nice and low.
Johnson Evinrude OMC Engine Tuner​
The only thing that can go wrong with this elegantly simple pump is the diaphragm.----Available new all day long!
doors67us
Can a guy use , seafoam,or something similar?
Crosbyman
some like seafoam some don't ... it fixed up my Honda snowblower cough.
never had to install my china copy carb.
