VRO conversion to Fuel pump 1994 E60TLERV Evinrude
SS Ghetto
Looking for recommended fuel pump (hopefully part # and source) for reliable fuel pump replacement. I have disconnected VRO so only need fuel pump (current original is leaking). See wide range of options and prices when searching so am a bit confused.
Thanks
The pump you want is the 438557.-----I do not use the cheapo Chinese ones.----But your choice.----They were mounted with a bracket.----But you can hold it in place with a ty-wrap.-----Remove the pulse limiter and install a simple barb fitting.----your location ?
SS Ghetto
Thanks for the quick response! Much appreciated.
SS Ghetto
location": Hickory, nc
Sorry----Too far away for you to walk over and get the bracket.
Maxrules specializes in that conversion. They also have rebuild kits for the gasoline side of the OMS pump.
