anthonyk85
Thread starter- Joined
- Mar 16, 2024
- 4
What would cause my 2018 25hp mercury not to build rpms when under a load
Boat has a 20 inch transom running a long shank with a 9.5 pitch prop. Compression is setting on 115 on all 3 cylinders. Have not changed plugs yet. But got fresh fuel. But in the spring of last year I put a breakaway plate on itWrong prop, bad fuel, too long of a motor, bad plug, low compression.....
Is this a new problem on an existing motor, or a new to you motor?
Try it without the plateI put a breakaway plate on it
Ok ill try taking it back off but put it on cause I have tilt and trim on the motor and the river I run has alot of logs in itTry it without the plate
Yes sir it's an efi. Ok thanks I'll have to take it to the shop and have it checked out. I know nothing about the 4 stroke enginesLeave the plate on and set cavitation plate about 1" below pad. Is it a EFI ? Could be a injector or ignition problem. If a carb model 4S could have a carb problem
