Rpm's
anthonyk85
What would cause my 2018 25hp mercury not to build rpms when under a load
Wrong prop, bad fuel, too long of a motor, bad plug, low compression.....
Is this a new problem on an existing motor, or a new to you motor?
anthonyk85
Boat has a 20 inch transom running a long shank with a 9.5 pitch prop. Compression is setting on 115 on all 3 cylinders. Have not changed plugs yet. But got fresh fuel. But in the spring of last year I put a breakaway plate on it
Faztbullet
Leave the plate on and set cavitation plate about 1" below pad. Is it a EFI ? Could be a injector or ignition problem. If a carb model 4S could have a carb problem
anthonyk85
Yes sir it's an efi. Ok thanks I'll have to take it to the shop and have it checked out. I know nothing about the 4 stroke engines
