No crank!?! Electric issue??
cameronr
Hello everyone reading this.
I have a 1975 Evinrude #50573B
The motor runs (when crossing the solenoid)
I am having an issue with no crank when I turn the key. I tried the following steps before coming to ask for your advice.
trying a known working set of controls
  • Replacing the solenoid
  • Checking for neutral safety switch (there is not one that I could see)
From my very basic understanding the battery connects to bottom of the solenoid, the starter connects to the top. The small screw is for the ignition, and the other small screw is for the ground of the solenoid.
When I turn the key, power should be flowing
From the battery
To the solenoid closing the gap allowing power to the starter.
Since there is no neutral safety switch there is no other part that should be stopping power from reaching the starter
The three parts the could be killing my electric start from cranking is
Ignition switch (I know is good!)
Wiring harness (maybe)
Solenoid (should be good??)
Is there anything crucial I am missing that would STOP the engine from cranking?
cameronr
I would meter your maybe.
Going to try. I have watched so many videos and I’ve never felt so stupid trying to use a tool.
Give me an engine that the electric is working, I’ll get it running. That’s about it.
cameronr
cameronr
flashback
all you need to do is look for continuity, you will find a short somewhere.
Crosbyman
Replaced the fuse, and the motor cranked for like 1 second. Not super confident in the fuse because I pulled it from an old motor. Going to go pickup a newer multimeter and see what’s going on
so did you install the proper amperage rated fuse....??? then what happen did the fuse blow ??
if it blew right at KEY ON remove any extra accessories hooked up on the accessory post of the switch ... just pull the ACC wire and retry
if ok and fuse no longer blows at KEY ON you have a problem on the accc wire possibly wiring grounded or a bad accessory drawing to many amps
yet if it suddenly blows during START only you have a short on the START wire or a bad solenoid drawing to may amps
disconnect the start control wire on the solenoid post (check color code from switch S post ) and turn the key to START... if the fuse blows the wiring is grounded - chaffed somewhere
if it only blows with the solenoid connected then the solenoid is suspect
cameronr
if it blew remove any extra accessories hooked up on the accessory post of the switch ... just pull the ACC wire and retry
if ok and fuse no longer blows you have a short on the ACC wire or a bad accessory ....
I went to the store to get a new multi meter, I clicked the positive on the small positive side of solenoid, negative on the negative, and the solenoid clicked. Then magically the key started working again.
Not sure if god was just on my side but the electric start works now, I’m sure it was the fuse, not sure why it didn’t work earlier.
Thank you so much for your assistance. I would have never located the fuse. Just gotta run all of my cables, install the lower unit, and should be water ready! Thank you, again!
Crosbyman
just carry proper sized ...spare fuse in case ... not finding a problem can be worrisome 10 miles out :)
thanks for your feedback
cameronr
Yes good be a blessing 🙏 could be an omen 😡.
Gearcase was off, new water pump I hope?
Not quiet yet, got 3 outboards I’m working on right now. All 3 now run, now time to prepare with water pumps, grease, and ensuring all the bolts I took off are back on!
