johnbailey
Thread starter- Joined
- Mar 3, 2024
- 5
Volvo Penta 4.3 GL 1997
I replaced the starting relay and fuel relays as well as the starter. Boat starts for les then a second just like if you try to start it with the safety lanyard pulled. I checked it and also bypassed it. I am wondering if my coil is bad. According to the manual I should get 8 or so volts when the key is on. I do get 8 while cranking but milli volts when the key is on. Should I accept 8 with key on or only with key on and cranking. according to the steps posted below I think key just being on but I am not sure. Also if the purple cable coming into the coil should have 12 volts where would I trace that from. I get continuity form the ALT is that they supply for the coil or is it from the battery some how. Step 4 fails and I do not know where to go from there and the manual dose not go into detail.
here are the steps I found
Thank you for reading this and any help you can provide.
- Connect a multi-meter as per the manufacturers instructions.
- Disconnect the purple and gray wire connector at the ignition coil.
- Connect the positive lead on the meter to the terminal for the purple wire in the connector; connect the negative lead to ground.
- Turn the ignition switch to the ON position and check that the meter reads at least 8 V.
- Plug the connector back into the coil and disconnect the pink and brown connector at the distributor.
- Connect the positive lead on the meter to the terminal for the pink wire in the connector; connect the negative lead to ground.
