redneck joe
- Mar 18, 2009
- 15,371
Still leaking. Fake daughter and fake grandkids with me today so no real quantifiable testing but slightly better.
But it was a great day.
thought of that - would not my tilt nose to the air test do the same? Pretty sure I had enough water in the hull to be above that level but I guess i can try again. I did not get in the boat after nose up to look at water level.Im going to go with the thru-hulls
use some good tyvek tape. tape over the thru-hulls. then drop in the water
I've font a couple floors that's one of the reasons i don't want to and it really does not need it yet.Just a thought. 5 or 6 rivets that are "fixed" with blinds would not cause that big of a leak. That amount of water reminds me of when I had a rivet completely missing and it filled my boat to the floorboards in less than 2 hours.
I say "fixed" because you already know the blinds are a temporary fix. I did the same thing and started with 5 or 6. Then as I checked the hull I found more and more. Had over 40 by the end of a summer. Problem is solid rivets are structural, and blind rivets are not. I was just breaking all the weak, damaged rivets along a few seams but the leaking was manageable with blinds/sealant. Last run of the season before I ripped the floors up to fix it right, I ran her especially hard through some chop to give the rest of the rivets a test, and broke a bunch more.
Point Im making is take it easy on her until you're ready to remove the floors. Seems daunting at first but it's really not that bad to have to do. Other point is the leak is probably from the thru hole or seams vs rivets. But Id be checking for new broken or loose rivets after every trip.
got any links to this process?Tape some visqueen to the guwales to seal off the boat, cut a hole in the plastic and tape a blower nozzle in the hole. Spray soapy water on the hull and look for bubbles. I've done this, it works.
I just used some duct tape I had laying around. don't know what would be best for no residue, the duct did leave a bit. I suspect 2 inch wide painters tape might be a better choice.Sounds too easy, and cheap. What would be best tape that wont leave residue?
Have had a few names like that myself for their stores !!Homely Despots.
