Yamaha 2 stroke oil hose
maineiac5586
Master Chief Petty Officer
I have a new to me 2001 yamaha 130 v4 2 stroke. Previous owner cut the oil hose about 2 feet hanging outside the motor. Does the rubber oil hose from the remote mounted tank run all the way under the hood to the main tank or am I supposed to have a different material hose under hood? If so I would need to join the rubber hose to the other material hose obviously. I don't have another to compare it to so sorry if this is a stupid question..
just buy a new oil supply hose. its the same piece/material that runs from the tank to the connection under the cowling
maineiac5586
Thanks I got the new oil hose already. So the rubber hose doesn't run all the way to the under cowling tank?
maineiac5586
I see it now in the parts diagram. Thanks
maineiac5586
I'm thinking it's a good idea to change the under cowling fuel hoses. Instead of buying all the individual hoses do you know what size that fuel hose is? Might buy it in bulk instead. My gas hoses feel pretty hard to the touch is the reason I'm thinking of replacing them. Thanks
