Help
kmaines52
Hello I purchased a 1987 200 hp mercury black max serial number 0B197898 it lost spark so checked stator was bad 3985454 A36 was on it. But it calls for 3985454 A32 or3985454 A35 the difference is between 1/2 inch and 5/8 lamination thickness . So I don’t know which is the right one.
redneck joe
Welcome to the forum. I have no clue but dont worry you will get an answer
Dukedog
what color is your flywheel?.. did you measure tha lamination thickness of tha one you have?
if unsure of what/where ta measure its on tha page below of where ta measure.... jus blow it up a few times to be clear....
Faztbullet
A 398-5454A16 and up are all 16amp stators and same thickness, the A at end of part number is a series number. So a 398-5454A16 and up will replace it,as the A32 and A 35 are same thinkness.
kmaines52
My flywheel is grey and the one that was on there measures 5/8 but it not the right one.
kmaines52
According to the manual they are not the same
kmaines52
It also states that they require the use of a voltage regulator mine has this which I assumed was a rectifier
Dukedog
it actually shows up as an '86... if there is no regulator yours is a nine amp... 5454 A7 is what you need.... if its a 5/8 you can run ANY 16 amp stator with or without a regulator... some say that you can't run tha 16 without a reg but with good battery program it won't hurt a thing.. if you have any electronics and/or use tha trim a lot it will keep any sign of over chargin' in check.. i ran 16's on everything i had/built from stock 150's ta hot rod 280's without a reg and never a problem....
kmaines52
Thank you for the info so mine has this ( picture attached) which I assume is a rectifier
Dukedog
correct......... if it has a reg. it will be about tha same size mounted directly behind tha flywheel in tha middle/top of tha block...... looks like you will have one.. tha red and yellow in tha plastic sleeve should go to it...
kmaines52
Ok so the problem I am having is the stator that was on mine was a 3985454 A36 which is not correct so I don’t know if I need a 1/2 or 5/8 lamination for my motor
Dukedog
tha lamination thickness is irrelevant to motor.. it is to flywheel.. ya need ANY 16 amp stator ta go with your flywheel.... tha normal stator used with tha 1/2 is justa 9 amp (really old) stator.. i don't remember any production V6 that came with a 9 amp after '85/'86.. maybe even earlier? below is a complete list of merc numbers you can use.. a lot of these are superceded numbers
i think CDI uses 174 5456-16
kmaines52
Thankyou for the help greatly appreciate it. You are very knowledgeable and I need a guy like you on speed dial because I always have questions.
kmaines52
Thanks for all of you help I greatly appreciate it. I need a guy like you on speed dial cause I always have questions. Thanks for sharing your knowledge
Dukedog
was at it for quite a while (since early 70's).. sold out an gave it all up 'bout 10 yrs ago but still like ta help when i THINK i can!..... jus ask and if i think i have an answer i'll be glad ta share..........
'ole Faz is very knowledgeable on tha V6 also......
kmaines52
Thanks for the help I greatly appreciate it
