Oem vs aftermarket cool fuel pumps
rusty12
Anybody tried the aftermarket high or low pressure pumps for a mpi engines? The oem are around 500 aftermarket which look identical are 150 bucks. I usually stick with oem but I can see merc just buying them cheap and putting their label on then.
Scott06
Anybody tried the aftermarket high or low pressure pumps for an mpi engines? The oem are around 500 aftermarket which look identical are 150 bucks. I usually stick with oem but I can see merc just buying them cheap and putting their label on then.
If you can find an aftermarket Airtex (part of Carter) I believe they are who supplies the oem pumps.
