90hp lower unit to 120
ccfd072011
I am needing a lower unit for a 1994 V4 120hp. I found a 1990 v4 90hp lower unit. Will it work on my 120??
May have to check driveshaft length.----Will have to change shift rod.----Shift rod need to be set at the correct height.
Faztbullet
Will need to swap driveshaft to make work as one is CF and other is looper
