Best prop for a pontoon boat?
smokenjoe123
I've got a 20 ft pontoon with a mercury 850 (85hp) on it.This outboard has a 19 pitch on it now but I'm sure it's not the right one.
smokenjoe123
I've got a 20 ft pontoon with a mercury 850 (85hp) on it.This outboard has a 19 pitch on it now but I'm sure it's not the right one.Im looking for all around good performance.
You have to first get your motor height correct. Then you dial in the prop
My guess you will be in the 15p range
smokenjoe123
Thanks I was thinking a 15 p would be more appropriate. It don't have power tilt so I have to do it manually. I know it's not going to scream across the water but hoping it will run better than the 12 to 13 mph that my 50 hp does lol.
jlh3rd
I have a 24' pontoon with twin 25" tubes. It came with a merc. 60hp Big Foot, efi, 4 stroke. By myself on a cool day I might almost see 21 mph.
Its got a 115 on it now.
I can't see yours doing less unless there's a problem.
What is WOT RPM?
smokenjoe123
I don't have it on the boat yet.I just thought that a 19 pitch on an 85 hp is to much for a pontoon boat.
