what do you see wrong with this picture?
1975oday22
can anyone see what is wrong with this picture? any thoughts?
silverbul
Color code, engine oil? Not really sure what is supposed to mean.
1975oday22
take a closer look under the belt. that does not look like water........does this engine have other problems besides just a starter?
Looks like there is a lot of rotten wood in this boat.-----Look thing over carefully !!!
jbcurt00
Did a bit of clean up @ aisle 3.
Have a great week
What's this Merc in?
flashback
I'm a rookie but is that a normal setup for an oil filter? If that is an oil filter I can see how the bilge gets greasy...
1975oday22
that there my friend is i believe a water seperator from gas. correct me if im wrong. ?
Lou C
Yep anything on the rear or sides is a nuisance to get at.
Scott06
That is a remote oil filter pretty common on mercs. The fuel/water separator is usually down on lower left front of engine
the oil in the bilge may not be a big deal could come from corroded timing cover or from drive seal leaking into bellows and into the boat. What would worry me is the general age of the boat , looks like it had some plywood work done, so the likely hood someone replaced the deck or did a deck over is high. If the deck was properly replaced thats fine but I would check stringers and transom for rot.
1975oday22
as i said earlier on Scott. i have walked away from this one.... not worth my chief. I do have my eyes on something much better now. will post if it comes through.
flashback
Does the oil in that filter drain back to the crank case when the engine is off? I just see a mess when changing if it doesn't...
Scott06
Don’t know never had one. Would assume they would drain out like max when changing. There must be some way to not make a complete mess
Lou C
My brother has a 2020 Merc 4.5 with the same design filter & it doesn’t make a mess when changing it. A little leaks out but not much.
Lou C
If this boat didn’t have a remote filter mount there’s no way you could change it the way the boat is designed. Modern boats scare me!
