89 Johnson 70HP 2 STROKE bogging issues
Aurobinson
I recently purchased a pontoon with a 70HP Johnson on it. I took it out today for a test run, when going out it seemed okay. However, when returning I tried to accelerate and it would not go more than 20% throttle. As I was heading back if I hit the choke the boats RPM went up and took off for a few seconds & then went back to bogging. I’m new to this, not very familiar, just trying to see someone’s opinion who may have more knowledge with these 2 strokes. Thanks in advance!
flyingscott
What happens if you pump the primer ball when that is happening? What is your compression?
Aurobinson
Unknown on both of those, will have to give it a try and let you know the compression. Thank you for some starting points!
Clean the carburetors.----And does the fitting for the tell tale come off the side of the exhaust manifold ?---Or off the top of the block ?
