- Mar 8, 2009
- 44,324
No,
I said it does not have a slave like, I said
The older ones looked like this
You have 3 relays on top, pic post 18
One of the 3 relays on top "IS" the slave relay
The other 2 are main power and fuel pump
Your slave relay is not the typical one found on most, is the same as the fuel pump and main power relays. There are 3 of them and look for the one with the yellow/red wire on it, it will be the slave
https://www.mercruiserparts.com/bam/subassembly/31751/12840/40
The start, main power and fuel pump are all the same. The trim may be different and have not compared
