drain 9.9 fourstroke float bowl?
boatdude100
Motor went partially underwater with the heavy rain. Where exactly is the screw to drain carb of this motor please?
ThomW
A serial number or even the year of your motor would go a long way in getting help. There are a lot of 9.9's out there.
boatdude100
Excellent point thank you. 2010 9.9 fourstroke model 1F10201FK
The answer my friends is that the float bowl/carb drain screw is the BRASS 8mm screw to the upper left of the hose that goes down out of the carb.
QBhoy
It will be underneath the bowl. But for all the time it will take you…I’d take the whole carb off and clean her out.
