jimmbo
- May 24, 2004
- 14,689
Turning the Throttle down, retards the timing, which is how the Idle Speed is set. If retarded too much the engine will die. The carb, is fully closed at idle. 1 1/2 turns out from lightly seated is where the Idle Mixture Screw, is initially set, and is adjusted once the engine warms. Final setting is usually leaner. Idle speed is about 600-650rpm, in gear
