Lou C
- Nov 10, 2002
- 14,605
Isn't yours an Ecoboost? V6 that puts out 470 ft lbs?
The Jeep tows just fine, for what I use it for. The boat weighs 5000 lbs on the trailer, the Jeep is rated at 7200 lbs, I don't tow with cargo in it, so just where is the "problem" there Bruce?
Oh and by the way, it has a better 4x4 system than ANYTHING currently on the market and will never have even a bit of wheelspin on any ramp.....
2 speed automatic transfer case
electronic locking rear and front differentials
to my knowledge, no other vehicle has that. The only one that was at the same level of traction was my secretary's Mercedes GL 500 with 3 locking diffs. On the Jeep it is all automatic, you can also use 4 low if you want.
Now if someone is towing with it loaded down, max cargo, over the tow rating limit, well that's just plain foolish.
I've driven this thing all over the soft sand beaches of Long Island, and the Quadradrive-II system works great, it goes anywhere a Wrangler does, as long as I have enough clearance.
You are right V8s are hard to find on late model Grands, however I have found a few Grand Cherokee SRTs that have the same drivetrain as the Challenger 392 Scat Pac. Drove 2 of them and they are FAST....
