18 horsepower 1969 evinrude
harp2822
I have done everything on this engine to include......
New points and condensors
New fuel pump
New gas lines
Rebuild carb and had it boiled
New thermostat
New plugs
Still can't get it to start.
Can any one help me out?
lindy46
Checked spark? Spark should jump at least 1/4" in an open air spark tester. What is the compression?
New fuel pump
New gas lines
New thermostat
New plugs
aae0130
Not enough info……Describe what happens when you attempt to start it……what are you hearing?
brodmann
So what time do you think he's expecting us at his house with our tools?
brodmann
Sorry about my smart a** comment. The guy just joined the group today. Maybe he's struggling to navigate his way to the responses to his post.
Sorry new guy!
Crosbyman
try a shot of fuel in the carb face... what happens ??
tried switching plug wires around ?
did you pull the choke to start it ?
jimmbo
New fuel pump
New gas lines
New thermostat
New plugs
Compression, Spark, and Fuel are all needed at the proper time, and the correct quantity for the engine to run.
Does it have a Spark that can jump a 5/16" gap?
Is Fuel getting to the Carb? Is the Float set correctly?
Have you done a Compression Test? If yes, what are Numbers. If No, why Not?
harp2822
My current problem is no fuel to the carb
harp2822
Compression test was 98 on one and 96 on the other
harp2822
It will pop and that's it. Choke wide open after the squirt
silverbul
if you have spark, shot of ether in the carb, brrr for a second you can nail it down to fuel not getting to carb then backtrack. fuel filter, gas tank vent valve, etc etc.
silverbul
imo, dont try to overchoke it, maybe just let it sit, pull plugs, clean and try without choking like i do when i talk to my wife. seems to work most of the time.
jimmbo
If no fuel is getting to the Carb, plugged Lines, plugged pickup in the tank, Fuel Pump defective, or Hoses reversed. Air Leaks in Fuel Line.
Inlet Valve not opening, due to Improper Float Adjustment, or Installation
Does the Primer Bulb firm up?
harp2822
I've pulled the plugs 50 times hoping to see a wet one. Dry as a popcorn fart
harp2822
Bulb is hard. Took carb feed off a couple times and squeezed the bulb. Gas everywhere.!!!!
harp2822
Should the tank be almost the same height as the carb? Like maybe it's too much to pull fuel uphill?
jimmbo
No, tanks are usually a few feet lower than the Carb.
tphoyt
If you have fuel at the carb but not through it it’s time to revisit the carb. IMO
Still doesn’t explain why you’re not at least getting some life when squirting a bit of fuel in the carb.
Did you torque the flywheel when you put it back on? Could have sheared the key if not.
harp2822
Current update, found the half moon key sheared about a week ago. It's been replaced.
I am getting a couple of grunts when spraying 3 to 4 large squirts. It ran for about 1 to 2 seconds.
harp2822
FINALLY!!!!!! Got her started!!!!!
Anyone know what the head temp should be? Mine was 214
