1975 6hp evinrude (carburetor issue)
BananaMan
Afternoon everyone,
I have a 1975 6hp evinrude I recently bought.
Started up on the second pull.
Ran some seafoam through it as it seemed the top speed was low. Sure enough after a couple runs with the seafoam added in the tank it started running a bit quicker, it was finally making a wake behind my 12 foot aluminum.
Ran like this for about 2 days.
Now it's back to running with less power at WOT
I'm assuming the carb needs to be cleaned.
My question is, can I take apart the carb, clean it and put it back together without a rebuild kit?
The idle isn't great on the motor either. I can rev it up to high RPMs in neutral. But when I leave the throttle in a position. The RPMs vary without touching the throttle. I'll upload a video if I can
Do a compression test.-----The original head gasker were not the highest quality.-----New gaskets are improved with Sierra being the best deal.-----And does spark jump a gap of 1/4" on a test device on both leads ?
BananaMan
At the cottage for another week, won't have any major tools until I'm back home with the motor.
But I do plan to make this happen.
