90’s tohatsu m40c water cooling
AKwrencher
Alright first time posting to one of these things but I’ve been researching for days and can’t get a straight answer.
I just got an old tohatsu labeled M40C with a tohatsu 35hp cowling. In the manuals I have found it is saying there is no pee hole and only the water out of the back idle ports, does anyone know if this is correct?? I see where the pee hole should be but it is completely solid blocked off inside and before I go stabbing around in there (probably end up drilling) I wanted to know if this was supposed to be blocked off for some reason. The manual shows the M40CEF and CEP with a pee hole as the cooling water check port but for the M40C it is pointing to where the idle port is. Please help. Thank you in advance!
AKwrencher
Also it is a 2-stroke I forgot to mention, I don’t think that would matter though.
AKwrencher
CEF is tiller CEP is remote. They are all 40C motors.
Awesome thank you!! So there’s no difference on the cooling system for any of the 40C’s then correct? Just triple checking
