no start
johnlewi
26 ft peterborough 260 hp 350 mercruiser that does not start after i rolled it over for 15sec. i tried again got nothing no click no dash lights nothing read there is a 90 amp fuse on starter that will do this on starter but can not locate oping somebody can help me. i found 50 amp breaker has a buttom on it but can not push in but got power on both side of bolts
nola mike
can i jump starter from solenoid
You can, but why? It's turning over, but no gauges at your dash? Sounds like you aren't getting power to the purple ignition/dash wire from the ignition switch. I'd start there. You can confirm that you aren't getting power to the (+) side of coil.
alldodge
You can but by the looks of the pics start by removing all the cables and wires and clean them up to shinny metal. Also the ground cables. There is a lot of corrosion.
Scott06
There is no 90 a fuse on yours - it would be a square cube (3/4"x3/4") on the starter lug between the bat cable and orange cable from alternator. Not sure if your engine originally didn't have one or someone took it off.
Start with the simple stuff like the cable mentioned. Yes you can jump the slave solenoid and this can be helpful to see if it works you can rule in or out issues with parts of the system like helm switch/wiring and battery supply .
Willing to bet that if you clean the cables or maybe replace (measure ohms in the cable) including the grounds your issue goes away unless something mechanical is locking up the engine. Can check that by removing spark plugs - should be able to turn by hand or strap wrench on pulley
johnlewi
it was turning over but then it stopped and had nothing no roll over no click no nothing, i put screw driver across 2 big bolts on solenoid rolled over for a few sec. then nothing it would not roll over
johnlewi
should u be able to see that square in pic i sent or do i need to go right to starter
Scott06
should i put 1 on everything was great last year when i used it
I would find the factory wiring diagram for your engine serial number and see if it was there or not. Not sure what year as I have had older boats that I don't think had this fuse, so yours may not have had it at the factory. If it wasn't there originally I wouldn't add it rather focus on getting it running and in good shape.
alldodge
The fuse is used to protect the battery if the alternator shorts out.
This is not you current problem, install one if you wish but will not change anything now
You can crank and then it won't crank or even click
Meaning corrosion (bad connections) and /or bad key switch
