Seasons Recreational
- Jul 18, 2023
- 35
Hi all, newbie here! I just bought my first boat, a 1960 Sea King 14'. I also purchased a separate outboard, a 2004 Johnson 9.9 4-stroke. I think that the shaft length might be a tad long for the transom. It's about 3-4" longer than the transom is high. Will this be ok to run on this boat?
I am also considering replacing the transom plywood and there is an opportunity to raise the top of the transom (the existing transom drops in the center). I could gain about 2-3" of height in the transom if I do this, raising the motor and prop almost to where it needs to be. Is this advisable?
Attached photo showing the dropped transom in the center.
Thank you!
Thank you!
