Charles Greg
Thread starter- Joined
- Jul 3, 2023
- 4
Hello,
I'm having an issue with the motor not wanting to go in to forward gear while running. It goes in revers fine but in order to go forward I have to hold the shifter with a lot of pressure just to limp back to the dock. It was doing fine all morning, but about 3 hours later is when this issue popped up. The odd thing is, I've had the motor a few years and this has happed in the past. I would shut it off and spin the prop by hand while holding the shifter in forward - then back to neutral - start it then it world go in to forward no problem. However wouldn't work this time.
I've tried adjusting the linkage, I've also taken the lower apart and inspected the dog/gears and didn't look too warn to me. The lugs on the dog are a tiny bit rounded and the grooves in the gears are as well. However I'm thinking the lugs on the dog might be worn down in thickness. I can't seem to find any measurement specs on how thick the dog is supposed to be lug to lug and the depth of the grooves in the gears. I measured the dog with calipers and it is 0.921". Has anyone else experienced a similar issue? Obviously just replacing parts would normally be easy, but having a hard time finding them - also not sure it would solve the problem.
Here are some pics, I'm thinking those wear grooves on the dog are not supposed to be there?
