My boat run slowly. 120HP,2.5L,1989
What did you set the timing to? What did you set the dwell to?
If your dwell and timing are in spec, the low compression and fuel system are the two other issues to address
Low compression means the motor comes out and goes to a machine shop to be rebuilt
Fuel system.
Start with the contents of the tank. Check your fuel pressure, inspect the anti-siphon valve, fuel vent, etc
liusigou
Fuel system.
I did set the timing according to the following video , 13,4,2 will be fired. Really I did not know anything about dwell. Could you please explain me how to set dwell? and I went Canadian Tire store and asked for dwell and nobody knew about it.
Also what is the cost rebuilt the cylinders?
You need a dwell meter to set dwell
If you do the assembly labor yourself, about $1500 for a rebuild
If you pay for the labor to tear-down, clean, inspect, and reassemble. About $2500. However with you being in Canada, Call around
liusigou
There is an thread to add some cleaner into cylinder and the compressures was up. Can I do so?
OK, here's the update: I soaked all cylinders with Yamaha combustion chamber cleaner for about an hour. Then I idled it up and down (gently) for a good 10-15 mins. Took a compression check (warm) and here's what I have now:
Cyl#1 (125)
Cyl#2 (130)
Cyl#3 (126)
Cyl#4 (116)
Really I will give up to fix the old motor. A lot of time and money are needed.
Is there any simple way to add the cylinder compression?
alldodge
You have done all that can be tried to get it up other then machine work
Could do a valve job but with all the oil seen on plugs it's time
Find a 3.0 and Alpha 1 Gen 2 and drop in. Plenty in rotten Bayliners
Will be less than rebuilding what you have, even paying customs, VAT, etc
liusigou
Hi Scott, should I drop the Yamaha combustion chamber cleaner into the cylinders through the spark plug hole? Will it damage my engine?
alldodge
Can I apply Yamaha combustion chamber cleaner? How?
I understand your looking for like a mechanic in a can, and I don't see it helping.
It's sprayed down throat of carb when motor is running at high rpm. Need to boat in the water because garden hose may not supply enough to keep impeller safe from being damaged
Rev motor up and start spraying down the carb.
liusigou
What kind of product do you suggest to apply?
alldodge
There is nothing that I know of that can be done to fix a wore out motor through spraying or pouring. Only way to fix a worn out motor is buy another or fix the one you have.
You could pull the head and have it rebuilt, normally isn't expensive. A couple 100 which would include valve job and gaskets.
This "should" increase compression, but if rings are weak/worn bad enough, then the motor will have more blow by
dubs283
At 3000 rpm under load pour a quart of distilled water down the carburetor
The water must be purchased locally, no cheating with tap water. If a spring is located nearby this water will suffice
Don't let the motor die when applying the water.
Boat motors run on water, who knew?
dubs283
There's little difference between the combustion chamber cleaner you mentioned, power tune and water
Steam clean the engine
Another trick an ol boy told me once is to add a quart of atf to the crankcase a few hours prior to an oil/filter change. Frees up sticky lifters? Might just be a ford thing
liusigou
Could I do a cleaning for the carburator? I have bought a can of Sea Foam
alldodge
Dangerous action. I prefer not trying doing so
It's not dangerous so long as you don't put enough in to kill the motor. I use to do it as a youngen with a garden hose (we even drank from the hose) o_O
IMO want to talk about junk and that's seafoam. Folks take good clean gas and dump seafoam in it. Snake oil so far as I see it
dubs283
I've always assumed oem marine engines are designed in house to run on fresh, clean, gasoline (where appropriate)
The engines will not run to top performance on anything but only the fuel they are designed to consume
liusigou
I pulled my boat into lake this morning and run the motor with gas mixed with the sea form about 20m. Then the boat can run with 33 miles. But later it shut off and failed to get fired. So I got back my my trolling. I checked the third cylinder's pressure is still 100. Battert's voltage is about 11.98. I will try to start it at my driveway after the batter is charged.
