ShoalSurvivor
- Aug 1, 2012
- 256
recently purchased and installed a Carter AFB-4.3L-Marine-Electric Remanufactured 4 Barrel 4.3L Marine Carburetor - Electric Choke. Same model, installed easy.
I have been diagnosing fuel supply and bypassed the oil pressure sensor to test the fuel pump.
This is what I'm seeing at the carburetor with the ignition on, without starting:
View attachment IMG_6399.MOV
I would expect the float and valve to stop that flow and suspect a problem with this carb.
Is this expected?
thank you!
Is this expected?
thank you!
