WhiskeyNoise85
Thread starter- Joined
- Dec 28, 2021
- 47
Hello again everyone. Ya boy whiskey needs some helps from the pros again! First off OMG do this motor usually drink a TON of gas??? I mean no exaggeration about 1/2 a gallon a mile at 10-11 mph. (The motor it on a 21 ft pontoon)
Sorry this is gonna be a pretty long post but here goes. I'm a pretty good mechanic and I can do just about anything amd diagnosis anything but this motor has me stumped. 1986 85 hp force so when I go about half throttle it comes up to rpm and will run About 7..8 mph all day. But falls of its face in a bog if I go a hair more with the throttle...sometimes I can giggle amd wiggle it up to about 3/4 of WOT (about 10 mph). But if bogs anything after 3/4 now. And i know its a pontoon its not suppoused to be fast but its not right....ya know? I should have WOT.
So, I did a full carb clean,new primer ball, checked gas tank vent.And lines Replaced the diaphragm thing on the motor. New plugs.set the fuel idle mix screw to 1 turn out(bc that's where the Manuel says to start) Had a buddy drive and brought it up to its half throttle speed and pumped the ball and nothing happened. The ball wasn't "HARD" and it wasn't collapsed.
Now check this out . I could reach the butterfly control rod so I twisted them to WOT and VROOOM 16 17 MPH!!!
so please help me understand this if you could.
Ohhh. One other thing I checked the spark plugs last night and one was like super clean. Like brand new and had some oil on it...Pic on thread.
