Alpha 1 Gen 1 trim Cylinder air Bleed Procedure
ddrieck
Was fishing with my son over the weekend and I ran a #10 circle hook into one of the trim cylinder lines and punctured it. I am going to order new lines from Sterndrive and looking for the correct way way to bleed the air out of the system. Mainly wondering if I just need to cycle in and out until the oil decavitates or should I bleed the air by cracking the fitting loose while someone operates the trim switch?
Replace line. Cycle up and down a dozen times
