ECM Replacement
DClark
As title says, I am replacing the ECM on my 2002 6.2 MPI (no power to fuel pump relay from ECM) I have gone through all the normal testing procedures and I'm just not getting any signal from the ecm to the relay so I am replacing the ECM (after hours of dead ends finding one)
My question is, are these like doing an ecm on a vehicle where I will have to have it "flashed" or Programmed after its installed? Or is it just a plug and play?
May sound stupid, but this is the first ECM issue I've run into on a boat.
Fun Times
It will be plug and play.
What design ECM do you have? MEFI or 555?
Have you found one yet? Engine serial number should help too.
DClark
555 - ECM Part number on original is 864273-3 however I have found it was superceeded by part number 864273T07
Engine Serial number is OM330428
Fun Times
Confirmed that is the correct part numbers
5864273T07ECM, Engine Control Module864273T3SS/ACT
$2,489.79$2,282.441
If you have the time then there are a few places that might be able to inspect and repair your old 555 ecm if needed and possible.
DClark
I will look into that, thank you for the tip there. I think the person that ownes this boat will likely just replace it to lessen his concern that it will happen again. I have found one on SeaWay Marines website for just under 1700 (they state it has to be drop shipped from Mercury) but its the best option I think at the moment.
I was just unsure if it needed to be programmed after install and I am amazed and thankful for how quickly there was a response here :)
Thank you for the help!!
Fun Times
May want to call SeaWay first before ordering, I was always under the self-impression their website was a bit outdated at keeping up with the times...I could be wrong through too.
Good luck.
DClark
Good luck.
I did call them, the ECM will have to be drop shipped. However, after speaking with the customer we will be going with the attempt at a repair. Thank you again for that lead.
