Alpha drive for a V8 whats the ratio?
crazy charlie
Have twin 5.0 1988 Alpha drives.Have an opportunity to buy a spare drive and it claims
to be a 1.47 ratio.I always thought the V8 was to be a 1.50 ratio?? Charlie
dubs283
Reason for difference is the ratio in the gear case.
1.47 will swap fine for a 1.50 and vice versa.
Is more important for twin setups to have exact ratio however with the difference being close enough it should work okay. Only item I'd verify with an increase of ratio is total advance of timing with the same prop.
jimmbo
I/O makers often offered an engine with more than one Ratio, to make it easier to Prop, over a larger variety of boats, mainly to reduce the number of Prop a dealer need to inventory, and to keep the Prop choices closer to where the Dia-Pitch relationship made for better Efficiency.
Both Drives need to be the same Ratio, as any mismatch will create a variety of problems/issues.
Close only works with Horseshoes, Grenades, and Nuclear Weapons
dubs283
The 1.47, 'n 1.50 are the same,.....
same...ish
Exact ratio is (example) 1.47 engine revolutions per 1 (one) revolution of propshaft.
Again, only caveat I have is if using the same prop it's best to determine the engine isn't consuming itself from too much timing advance
5.0's usually come with 1.62:1 drives
5.7's come with the 1.47:1
there actually isnt a 1.5:1 drive. it has always been 1.47:1 for them
Horsepower​
Engine​
Year​
Ratio​
120 thru 1404 cyl. One drive1971 thru 791.94 / 20-24
170 thru 1904 cyl. One drive1971 thru 791.81 / 17-19
1656 cylinder1971 thru 791.62 / 24-24
188 thru 260V-81971 thru 791.47 / 20-22
120 thru 1404 cyl. One drive1980 thru 841.94 / 20-24
170 thru 1904 cyl. One drive1980 thru 841.81 / 17-19
1656 cylinder1980 thru 841.62 / 24-24
188 thru 260V-81980 thru 841.47 / 20-22
120 & 1404 cylinder1985 thru 891.94 / 20-24
170 thru 1904 cylinder1985 thru 891.81 / 17-19
198V-81985 thru 891.62 / 24-24
198 thru 260V-81985 thru 891.47 / 20-22
jimmbo
They are close, but keep in mind there is another drive, next to it, and that difference, however slight, may result in issues
QBhoy
I always thought that an older era alpha may have came in 1.5 ratio. Then later replaced with the 1.47 ratio, sometime in the mid 90’s or close.
Anyway, it’s unlikely that you would currently have either, mated to your 5.0…unless it’s the rarely seen combination of it and a 5.0 mpi.
dubs283
Yes
R/MR/Alpha One were only offered in 1.50, not 1.47
Gen 2 had both ratios available
I reread OP and see 1988 which would be in the vintage of Alpha One and if oem wouldn't be available in 1.47.
Guessing OP is looking at a gen 2 for replacement which wouldn't work on an Alpha One bellhousing
QBhoy
Yes
I’d say you’d be right about the above. But I still think it unlikely he would have or be looking for a ratio like that. Could be wrong. The exception might be twin engines. Not sure I’ve heard of 5.0 having as high a ratio, unless it’s an mpi and a performance hull.
jimmbo
It would have to be a very light hull to use a 1.5 on a 5 liter, otherwise props in the 14 - 17 inch pitch would be needed. The 1.5 ratio was more commonly used on the 5.7
QBhoy
100% spot on. I can’t think of one around here, apart from mine that has that ratio and a 5.0. Sometimes wonder if I’d rather a little less on the ratio. Just me idle wondering about the constant hunt for prop perfection though 😂. Would love to be able to run a 23” on mine. But the only one I tried (old school square vent laser 2), just would hardly get her out the water. Not too bad once she was going though. I run one of three props on her. 21” laser 2, 20” enertia or a 19” tempest plus. Might have thrown on a 21” tempest too actually. She will limit easily with the 19” t and the 20” e…with the 21” laser 2 from memory. But don’t think she did with the 21” tempest. 20” enertia is the usual on her. Still goes well enough
Yes
see post # 7 on R/MR/Alpha gen 1 ratios
see below for A1G2 ratios.
The OP has 1988 5.0 liters which should have came with 1.62:1 drives not the 1.47:1 drives
dubs283
True that.......
OP hasn't given us much feedback and I have read many threads about alpha drive swaps where information provided includes using a different ratio than was used oem. User is informed they should use a different prop to get the performance close enough to work
OP is a vice admiral which I'm guessing means they know a couple things about boats or at least have been provided a lot of info here. Maybe they tried a different ratio/prop combo at some point?
In any case this thread has some decent information for posterity
With twins, you need to keep them the same ratios and props
Scott06
Ye cant have one with a 1.62 and the other drive a 1.47 ...
If the engines are running 3000 rpm the prop shaft rpm diff between a 1.50 and 1.47 is 40 rpm. I doubt the throttle cables on a 1988 boat are synced that close.
At some point merc tweaked their upper and lower gear designs that the ratio changed from 1.47 to 1.50; 1.65 to 1.62; 1.84 to 1.81 etc. Merc lists them as interchangeable. We are overthinking this...
