JASinIL2006
- Feb 10, 2012
- 5,760
Hi all, I am changing my impeller and water pump, and after I split the drive and cleaned up everything, I noticed that there is some wear on my driveshaft just below the splines (see pic below). I can feel the grooves when I run my fingernail over them. I do not believe it was there the last time I had the drive open, a couple years ago. Last year, when I changed the gear, lube, the drive held pressure overnight.
Any ideas what might be causing the wear? I have the drive apart now because I am going to replace the water pump, so I’d like to take care of it while everything is apart.
Thanks!
Thanks!
