Topping off a compass, what to use?
crazy charlie
I have filled a compass many years ago and used "Compass fluid" as it was called at west marine .I now need a small amount to top off my compass and my west marine bottle only had a drop left in it.dont know why I saved it.anyone know what can be used to top off a few needed ounces? or should I just buy the entire bottle of compass fluid? Charlie
I believe glycerin has been used in the past.----Does the bottle indicate what the fluid is ?
flashback
Yea it depends on what's in there now, some manufacturers use mineral oil or kerosene..or maybe alcohol water mix so you don't want to mix them.. I'm familiar with Richie they used mineral oil for many years.
mvn
Looks like it's a synthetic form of mineral oil as it says it can be mixed with mineral oil in older compasses.
Mark
dwco5051
Don't know what the fluid is but if it is a Navy gimbal compass this is what was used on all the pivots. Only kept in stock on one ship in the whole base so every time we needed some we would have to send the new guy across the base to get it.
dingbat
Had to replace the seals and refill mine a couple years ago.
Turns out “Compass oil” is odorless mineral spirits. $8 a quart at the hardware store
Fill and put in freezer for a couple of hours
crazy charlie
I think your nurses are out looking for you.Time to go back to your room
crazy charlie
already have some of this,I will give it a try.thanks Charlie
