Gale 1959 SeaKing 5hp water impeller help
kbryant
Hello
I have the lower unit undone and it drops down about an inch but I can not figure out how to get the shifter linkage undone. Can anyone help me with a YouTube or guidance how to finish this job. Any help would be so thankful. I've been trying to figure it out for 3 hours now.
Posting a picture would help.----But I say you have to remove the powerhead to undo 2 nuts at the top of the shift rod.----Actually quite easy.
kbryant
Hello
This is how much of a rookie I am when it comes to outboards. What's the power head? I know probably a stupid question but not sure. Thank you for your time.
kbryant
Hello
Maybe this is too much for me, but I want to give it a try if anyone can help a little..
If it is the motor built by Johson / Evinrude then about 7 screws need to be removed.----A few hoses,-----Then the engine block lifts off.----Not hard at all.
kbryant
I will give it a try and see . Going to work on it tonight. Wish me luck! Thank you for your time with a reply. Any help is appreciated
I have not seen pictures of this 5 HP Gale !---But It is not like the pictures of the 12 HP.----Find You Tube video of this job on a 5-1/2 HP Johnson / Evinrude up to 1965.-----Will show what needs to be done.
F_R
Procedure is similar to 1955 Johnson 5.5hp. Powerhead (think "engine") must be removed to access/disconnect the shift rod. Remove rear cover #28, then 7 screws holding powerhead on. Note some screws are longer than the rest. Disconnect any hoses/linkages as necessary. and lift powrerhead off. It separates at the gasket #24. It probably will be stuck to the gasket. You will need a new gasket. Remove the two nuts from top end of shift rod. It will be obvious when you get in there. With powerhead off, lower unit can be remover for access to the water pump.
kbryant
Omg
Can thank everyone enough. Thank you. Going to tackle this baby tomorrow.
brim_buster
I took this pic down and posted the 5 and something went wrong apparently
kbryant
Hello Everyone,
I got her apart and does anyone know of a website where I can order a new impeller for this out baby?
Most dealers would have it in stock.---#277181 Johnson / Evinrude part or 0434424 is superceded #.
