JOHNSON 55 HP TILT PIN QUESTION
maineiac5586
Master Chief Petty Officer
ON MY NEW TO ME 1987 55 HP TILLER MANUAL START LONGSHAFT I CAN'T SEEM TO GET THE TILT PIN INTO THE LOWEST HOLE ON THE SWIVEL BRACKET. IF I START IT THROUGH ONE SIDE IT COMES INTO CONTACT WITH THE TRIM ASSIST CYLINDER AND WON'T MAKE IT TO THE OTHER HOLE. EVERYTHING SEEMS TO BE AS IT SHOULD AS FAR AS THE BRACKETS AND THE TILT CYLINDER GO. i AM ASSUMING OMC WOULD HAVE MADE THAT LOWEST HOLE ACCESIBLE. I TRIED A SMALLER DIAMETER TILT PIN BUT EVEN THAT WOULDN'T GO IN WITHOUT CONTACTING THE TILT CYLINDER. NOTE THIS MOTOR DOES NOT HAVE POWER TRIM, JUST THE SIMPLE ASSIST CYLINDER (NOT THE TOUCH TRIM STYLE THAT USES A HANDLE TO PUT INTO RAISE OR LOWER POSITION). SORRY FOR SO MANY POSTS COVERING DIFFERENT QUESTIONS ON THIS OUTBOARD I JUST AM TRYING TO SORT IT ALL OUT. THANK YOU
rolmops
During the 36 years that that engine has been around it may well be that the bracket has been changed out for a non original one
maineiac5586
I don't think it's been changed. They come in half brackets that fit together. Motor is all original
tphoyt
I’m not sure why you would need a tilt pin if you have tilt assist. If you need to change your pitch you can move the bottom pin of the tilt assist cylinder to the appropriate whole.
whole----hole.----Sorry could not resist.-----Best to post some pictures of the set up----Looked at a couple of normal midsections here.-----Your set-up may well be custom.
maineiac5586
It's not tilt assist its a tilt aid. Tilt assist uses a paddle looking handle on the starboard side with a cable going to the cylinder. Mine is just a basic looking cylinder.
maineiac5586
Ok I'll get some pics. Going tonight
maineiac5586
Here's the pics. The last picture shows the pin making contact with the cylinder not allowing it to line up with the lowest hoke on the port bracket.
maineiac5586
Tilting all the way got me closer but still no good. I'll have to check brackets to see if any adjustments can be done
