2006 Mercury 9.9hp 4-stroke won't start.
mercury4str
Getting spark,as tested with inline spark plug tester. Does this mean that my kill switch, coil and CDI are good? When I pump gas tank bulb, gas comes out if the tube on top of the carburetor. Also fuel pump is leaking a little. Any help much appreciated.
saltchuckmatt
Maybe. Fuel pump should not leak, did you try to tighten it?
Are you choking the motor when you try to start it? Have you tried a short blast of starting fluid?
When was this motor last run?
How did it run for you last season ?----Do you run fuel out of carburetor when storing the motor ?
mercury4str
Yes, I use the choke. No I have not tried starting starting fluid. How would I get it into carburetor?
mercury4str
The motorwas last run about September last year. Before the non start issue, I was on the water and the motor revved up to what seemed liked super high rpm. I was working on trying to solve the rpm when it stoped starting.
mercury4str
It ran good until I was on the water in about September, and the engined revved up to super high rpm when I started it after fishing a while. I was trying to figure that out when it stopped starting. No, I do not run fuel out of carburetor, as I fish year round here in Texas.
saltchuckmatt
Engine rpms running up super high on its own might not be to good.
Have you done a compression test?
??----Super high RPM- ?-----Could be an issue in the lower unit.-----High RPM may have done damage to valve train.----Sheared flywheel key.-----Time to do some inspection.
mercury4str
I have not found a diagram showing the location of the flywheel key or the shape. Is it a cylinder or like a half moon?
