rolmops
- Feb 24, 2002
- 5,698
So I replaced the transom on a new to me 1989 221 Starcraft Islander and dropped my new 4.3 liter engine in. Everything looked fine until I tried to insert the alignment tool. It did not want to go into the coupler. I very slowly adjusted the front bolts from the very top to the very bottom, but it did not want to go in and always touched the top side of the top side of the coupler just a bit above the hole. I replaced the engine coupler thinking that might be problem,but it made no difference, next I replaced the gimbal bearing, that did not help either. I need the engine coupler to be a bit higher. One way to do that would be raising the rear of the engine by somehow adjusting the rear bolts but I have no idea how to do that. Any thoughts or ideas to solve my problem would be very welcome. Thank you,
One hour later.
I just read something written by Don about banging the gimbal bearing a bit to give it the right angle, could that be the solution?
Cornelis.
One hour later.
Cornelis.
