1997 115, bogging down
ian hendo
Hi Brains Trust, engine starts ok and runs at first ok, when I stop and turn off motor or even just idle I have problems accelerating again. Seems to bog down and splutter. If I give more gas it stalls.
Although if I slowly gas it up it, it splutters and coughs then finally runs ok and will run fine at higher rebs. Until I return to idle when it does the same again. Fuel delivery?? Thank you for any suggestions
How did this motor run for you last season ?----There are 2 different 115 HP model in 1997.----Post the model #----Post results of a compression test.
ian hendo
hj115sleua, only had it for 4 months. Issue started as a one off, and happens more and more often. I have new coils and plugs fitted. Engine has been serviced.
Compression Test
Cyl 1:115 Cyl 2:115
Cyl 3:115 Cyl 4:115
ian hendo
Compression Test
Cyl 1:115 Cyl 2:115
Cyl 3:115 Cyl 4:115
Compression test is from Oct
Does spark jump a gap of 3/8" on all leads ?----Perhaps test run with a different tank and hose.----Did you install a new water pump impeller 4 months ago ?
ian hendo
Update... Bought spark plug tester. Found no spark on 1 cylinder. Tested ignition coils and found low resistance on a 3 month old coil.
Trying again in the water this weekend.
Thanks for the advice
ian hendo
0.2 and 200, I wasn't getting a spark from the coil with those readings.
That was on an aftermarket coil that was 1 month old. Next purchase is a genuine coil!
ian hendo
My other aftermarket coil is reading 0.2 and 375... Much better
ian hendo
New coil going on on Fri, and will test and report.
Next job is carb rebuild x 4!
