6.5 hp evinrude start but won’t run
Tiki91
Have 6.5 evinrude that barely starts but won’t stay running has spark and 80 psi compression on both cylinders.just a ligh purr for a few second and that’s it.putting fuel directly into spark plug holes.banging my head against the wall on this one.
  • IMG_1223.MOV
saltchuckmatt
Try pumping the primer ball when it first starts up.....if that doesn't do it then you will probably need to go through the carbs.
Tiki91
Done all that .did you see the video?should run longer and faster with the fuel injected directoy into th cylinders
Does spark jump a gap of 3/8" or more on both leads , yes or no ?----Checked the flywheel key.-----Water in fuel.-----Have you cleaned the carburetor ?----Orange / blue stripe on the top coil ?
