Engine flushing
Brent2
I have a 1996 Chaparral Sunesta 230 that has always been on a lake but just got moved to the ICW. Is the engine cooling system a closed system or do I have to flush the engine and how? It’s a Mercruiser engine
Unless you have a heat exchanger, you are raw water cooled
You can flush with a set of muffs or a kit such as superflush sf-400
Scott06
Post a pic of your engine. If it has a closed cooling system you will have a heat exchanger that is about 4" in diameter and 18" long or so right on top front of engine - goggle merc closed cooling system to see what one looks like installed
Ayuh,...... Welcome Aboard,...... If you can see a radiator cap in the motor bay, that's closed freshwater cooling,.....
If you can't find a radiator cap,.... it's raw water cooled, 'n yes, you should flush it as often as possible,....
ROY WILLIAMS
I did the heat exchanger coolant on my MCM470 . I used antifreeze coolant 65% distilled water 35% ... the engine has the pervious owner [1985] ... THEN did the coolant pump [WATER ] then the CAM SHAFT CORROSION AREA..OF THE COOLANT SEAL PUMP...I did the cam shaft cap to setup the cam rod [heat it ] ... I did not use later and NO coolant failures .. also drain the sea water plugs drained it out ..sea water flush the heat exchanger ....fresh water ..
crazy charlie
Either way ,a fresh water flush after every use is the best possible care you can take of your mercruiser block,manifolds,risers,heat exchanger.If you are in a slip ,lay on your belly and reach down to your trimmed up drive and put muffs on it and run until you are up to operating temp.Charlie
