Rebuilding 1980 johnson 35 Cant split the case?
1reddog1
Rebuilding 1980 johnson 35 How do I split the case. I watched a video of someone hitting the cam shaft and the case opened. No luck for me. Any ideas?
1reddog1
Take the intake off and make sure all the bolts are out. Where did you find a camshaft on a 1980 evinrude 35 hp?
crankshaft sorry not a mechanic just looking for help with my diy project. Thanks for your reply
Is the tapered dowel pin out ?-------Is the carburetor and intake manifold off ??-----Is the lower seal housing off ?
Nobody can see what you are doing.----That is why we ask questions.----I have never had an issue getting one of the crankcases apart.----Have done more than one !
jimmbo
Getting the Name of the Part correct, makes it a lot easier for others to provide any Help/Advice. A Sarcastic response to some of the Best people on this Board, can get you on the Ignore List very quickly
Crosbyman
now that was not so mean...seen a lot worse and it goes both ways. I am certain FR was just being funny.
lets all use our nostrils more :)
F_R
Actually, I meant nothing insulting or funny. I just said in a few words what was said by others----look for some more bolts, like behind the manifold. I was in a hurry, as I had to go to the bank for an identity / money theft purpose. A stressful day.
jimmbo
It was a valid comment, a lot of people don't take the Intake manifolds off of many OMC outboards and haven't found the bolts hidden in there
Picked up a 94 model 9.9 years ago.----Crankcase cover had suffered because the 2 middle main bolts had not been removed.
1reddog1
You guys are all great at this. Thanks for the suggestions. The screw to remove the leaf plate stripped and I could not remove. I did not see any bolts in the service manual, so I thought I could split the case without removing. You all say there are two bolts beyond this plate. Thanks for your help! I am a rookie, my mistake!! All the best to all of you.
1reddog1
The screw is stripped and stuck. I broke off the removal tool in the screw head. Any ideas how to remove?
There you go !!---Just drill the head off.-----Remove the reed plate .----Remove the hidden bolts.----Cover will fall off.
