Kill Switch help
rmc10
has anyone got wiring diagram for 1979 85hp evinrude? I am trying to hook up kill switch. rmc10
saltchuckmatt
Are you trying to put a man overboard kill switch in?
If so I believe you want to hook m to m.
Tassie 1
You should start a different thread re your question.
This one was 13 years old.
rmc10
wiring is same as in your diagram. when I hook up black/yellow to kill switch on red side and black on other m or ground terminal it kills one side. Boat will shut off using key.
When key is turned to OFF----The 2 " m " terminals are connected.----When your kill switch / lanyard is activated the 2 wires on it would connect the 2 " m " terminals.----Not much to it really.
Crosbyman
nothing new under the sun ...:)
The idea is clear.----The 79 model 85 does not have breaker points.------The kill switch connects the 2 " M " terminals to stop the motor.
Crosbyman
I understood that ...we are dealing with a concept and now a "modern" solution of shorting 2 M wires
M's that formerly went into the Magneto.
The 79 model 85 HPmotor has a magneto system.---It uses sensors and no breaker points.
rmc10
The problem I am having is when I connect B/y wire to one M post and Black wire to other M post it kills one side when I pull kill switch.
