Window ?
ericcarr
I am in the process of restoring my 1990 sea ray sundancer and I need to replace my pieces of the side windows that the glass itself sits/slides on, it’s located all the way from the front to the back of the window, as you can see in the pictures mine are dry rotted & cracked/broken.anyone know where I can get some?
carlos515
The foam is called , windshield screw cover foam. Taylor # 1630 or 1631N possibly. You should be able to get it at a marine supply store.
ericcarr
OK great thank you. But what about the part of the window that the sliding window and screen sit on? That is what I’m referring to in the pictures
carlos515
Check out sealextrusions.com . They may have what you are looking for.Flocked lined rubber sliding window channel.
ericcarr
I’m not sure if it’s supposed to be rubber and just dry it out hard and brittle or if it’s supposed to be plastic but one of the pieces that I’m looking for goes under the sliding glass so I asked as a channel to slide in
ericcarr
They told me they only go back 7 years on them so they don’t carry anything
ericcarr
Anyone ever take a window out of a 1990 sea ray sundancer?
ericcarr
I didn’t put it here, I actually started a different topic, the admins must have moved it here….when I don’t get a response I start a new thread.
