saltchuckmatt
- Jul 19, 2019
- 3,286
No just missing like it wasn't supposed to be there. Inner one yes....outer no. Believe it or not the little rubber gasket was in n there!It’s out of sight on carb schematic, due to viewing angle.. Salvage carb may be best bet.. timsoutboard.com is my go-to..
Yes, but it would only idle for 2 three seconds unless I primed or held my hand in front of the carb. Classic dirty carb or so I thought.I wouldn’t think it would run like that. But if that nozzle gasket was in place, then the whole center casting (tube) would be isolated..maybe it would run..
Did it run before you pulled carb?
It be gone. No stuck broken off piece in the top and nothing in the bowl. Someone removed it and that ain't easy.Check the Float Chamber, other half of the carb assembly.
