Prop Contacts Trim Tab Only When In Gear Not Neutral
GTWarrior
Hey guys I just recently installed my new prop and took my boat out on the water. Everything was fine until a few hours in I hear my Propeller hitting my trim tab. This only happens in Forwards and Reverse not in neutral. I do not know what is causing the prop to shift upwards when in gear. If anyone has any idea I would appreciate the help. Thank You!
Bt Doctur
Something got loose, in neutral the prop doesnt spin
Scott06
Check everything is still tight. Not uncommon to have to trim the trim tab with different props nothing a grinder can clearance.
GTWarrior
Sorry to clarify my prop does not spin in neutral. I meant if I spin it by hand it clears the trim tab. But if I put it into to gear even without the boat running and try to spin it, the prop hits the trim tab
GTWarrior
My question is Why would it only happen in gear and not neutral. Does that mean something is wrong internally?
Scott06
There is normal fore/aft play in shaft that I think gets taken up when it locks in gear. Remove prop lock in gear and see what happens
I think it’s normal just need to check clearance when changing props
GTWarrior
Prop Lock? Sorry but is that the locking washer for the prop?
dingbat
What prop and drive?
Pretty common for prop changes to require a change of the thrust washer as well
tank1949
maybe transom is rotten and flexing?
GTWarrior
Hey, it's a Mercury Alpha One Drive and I will add a picture of the prop I'm using.
dingbat
Should be using this washer with the Flo-torque hub.
Make sure you torque the prop nut to 55 ft. Ibs. Required to fully set the flo-torque insert in the prop.
GTWarrior
Hey, would this work also?
Quicksilver 835257Q1 Flo-Torq II Hub Kit - for Mercury/Mariner and MerCruiser Engines https://a.co/d/gqaGXDQ
Scott06
No…. Says right on the prop box you posted - Quicksilver 835257K1 Flo-Torq II Hub
Pretty sure the Q1 part is the quicksilver version of the mercury K1 version. Merc and quicksilver use basically the same part number except for a digit or character. Same part sold through merc dealers or labeled as quciksilver anywhere …. Both require the correct thrust washer i suspect that the OP has a gen one drive i dont think the gen 2 has a steering tab…. Possible it was set up with pressed hubs originally
GTWarrior
So that hub kit with the thrust washer I linked should work then?
dingbat
Not a merc guy….so not familiar with part numbers other than those noted on the box
Shouldn’t matter. Kit comes with appropriate thrust washer
