1.75hp Tanaka questions
robert graham
Remove carb float bowl and check float/ needle valve….maybe clean inside of carb….spray carb cleaner and an air hose should do it…
robert graham
How do I do that? I was looking at putting a chainsaw valve on and bypassing the stock one but there are none available where I live. Were taking a trip to the "big city" today and I found something at Lowes that might work. Maybe put one of these on with an inline filter?
That sounds like a good plan…just keep it real simple for future trouble- shooting and cleaning…
jg121783
Replaced the valve and added a filter and it started right up. The old valve must have been dirty or something. It's a loud motor though. Any way to muffle it at all? Too bad the idle speed isnt slower but I can work with it. I'm just worried my canoe is gonna take off on me right away when I start it.
robert graham
That little screw on the side of carb should be idle adjustment….it runs right on the carb slide….in is higher idle, out is lower….
jg121783
I appreciate the help. Without it I might not have got this motor running. One other question. It it possible to relocate the kill button to a more easily accessible spot such as close to the throttle lever? Here is a couple pictures of the monstrosity of a boat that motor is going on. About to take it out on the lake for a test run.
robert graham
I guess you could run the kill button wires and button out to the tiller arm so you can shut off motor more easily….did you get your idle down low enough so the centrifugal clutch is dis-engaged when throttle is closed?
jg121783
I turned the screw out to the point that it was about to come out and it didn't seem to slow down much if at all.
robert graham
Maybe the screw you turned is the fuel mixture screw….set it back where it was…maybe your idle control is in the control cable or a different screw…
jg121783
That's the screw I turned.
jg121783
Got the boat out on the water today. The motor started and ran for a few minutes. It actually moved my boat at a decent speed. Then it died and the only way I could restart it is with the prop out of the water. As soon as I dropped it back in the water it died again. Any ideas?
jg121783
Just noticed the throttle lever was stuck and not going all the way down to idle. I fixed it and am adjusting the idle screw and the engine cuts out before the prop stops rotating. Should I turn the screw to the position right before the engine cuts out?
robert graham
That looks like the idle control screw….maybe adjust your throttle cable to have just a bit of play in it and then adjust your idle with the screw..
jg121783
Took it on the lake again today. Ran better than yesterday but died a few times on me and was difficult to restart. Out of the water it starts everytime now and runs until I shut it off. So it seems that it is having issues under load.
jg121783
Is it possible water is somehow getting in the carburetor? If you look at a picture of my intake and the one on the exploded view of the engine the one on the exploded view has an elbow coming off the end where mine does not. Could that be causing the issue and if so can you think of a way to cobble together some sort of elbow for it? Perhaps a piece of hose bent at an L shape clamped onto it?
robert graham
Yep,I noticed that piece was missing….but I doubt water is getting in motor enough to cause motor to run bad….but maybe fabricate some kind of elbow or pipe to clamp on just to be sure. Make sure your spark plug is clean with no carbon build up….some spray carb cleaner and an old toothbrush works….
jg121783
Here is what I rigged up. The engine actually seems like it runs smoother with that on. About to head out to the lake and test it out.
