Ryansmith1
Thread starter- Joined
- Sep 2, 2022
- 17
I recently started working on a 1982 Johnson 50hp J50BELCNR I picked up. Looked like it has been sitting in a barn for a real long time. I put pretty much a new everything on it. Wiring harness, coils, power pack, stator, rectifier, plugs, rebuilt the carbs/ fuel pump, new fuel lines new key switch and kill switch.
Both cylinders have 135PSI, both plugs have a strong blue spark, fuel pump is pumping but this dang motor won’t start. I have got a few back fires and some white smoke but that’s it. New battery and the starter is spinning strong.
If I hold the starter for a few seconds then left off the choke will open back up and some fuel (not a ton) comes out of the carbs. I double check the floats and they are set correct measurements. Both carbs are super clean. I was thinking the read valves were maybe bad so I checked and one of them had a gap letting light in. so I went ahead and put a new set of reeds in and still the same thing. Fresh gas too and that didn’t change anything. New gaskets for the power head, intake Mansfield, carbs, fuel pump and all that.
The only thing I can think of was maybe the lower crank seal is super trashed and it’s sucking air? I pulled the plugs out and put my finger over the holes and turned the motor over by hand and I could feel suction and pressure when the piston moved back and forth for both cylinders.
Also the timing in this motor is fixed based on the crank shaft and the only think that’s adjusted is the WOT timing. Thought maybe that was set wrong but apparently it’s fixed. I have been over wiring diagrams and even traced each wire to make sure it didn’t have a short in it anywhere.
I did all this as a fun learning project and was hoping to have a pretty sturdy motor to use. I have a little experience after restoring a few older motors, but this one has me stumped. Anyone have any suggestions?
