fuel pump 260 hp 350 mercruiser
johnlewi
hi looking to get new fuel pump, when i look at oem pump shows a spring behind arm after market replacement do not show spring, are they useable or not. thanking u in advance for your time
ROY WILLIAMS
put on your MCM engine the year ..serial #....
sdowney717
MIE 260 fuel pumps like these pretty common setup, and the spring, well, if the part is a match for the engine it will work. Maybe your picture is not oriented to show the arm spring. I would think they all need this spring to push the pump rod back up. Maybe some have a spring you dont see. On that parts site, one pump shows a spring, another does not but I think due to the angle of image, you can't tell.
Does your engine use the rod in the block style that moves the pump arm?
Skip aftermarket and buy the Carter pump that was originally on the motor. It's less than $50
sdowney717
I would not use the sierra unless Carter fuel systems went out of business
The Chinese knockoff brand you posted from Amazon is PURE GARBAGE
Hey a carter
Yes, that is a good deal there. Made outside the US or not.
Here a Carter pump says on the box, made in China
ROY WILLIAMS
CCP IS A LOT OF FAILURES .....
