Repairing salt water corrosion, holes on an aluminum boat no longer used in salt water.
Dbass4856
I bought a 1999 lund adventurer used in salt water. It has 10 holes in the hull from salt water. How can I stop and repair the corrosion and fix the holes? Most are the size of a quarter. Can't weld without tearing hull insulation out. Been told to rivet plates on bigger holes. What about smaller ones? How doi stop the corrosion from getting worse?
Welcome aboard
Cut out the bad material, patch as needed.
You may find that you have a lot to patch
