Burnt fuel pooling?
Jhayes780
Sorry I know everyone is probably sick of my questions by now but. I have an 83 Suzuki outboard 85hp motors that when I run in a trash can full of water it appears to run great. But when I stop running it, it looks like there’s a bunch of burnt fuel on the top of the the water it’s been running in. Any suggestions as to what this could be?
saltchuckmatt
Unburnt oil and gas, totally normal.
99yam40
over oiling maybe or one or more cylinders not burning fuel properly
99yam40
sorry, just notice he said burnt fuel and oil, not unburned.
so that burned fuel and oil comes out the exhaust
Jhayes780
I mean it’s dark so I’m assuming it’s burnt. The water also appears to be coming from the exhaust and not the telltale, but there was definitely some dirt and debris in the hole. So I’m hoping that was it. This engine appears to run well just trying to fine tune it I guess
Jhayes780
080AF7D8-8FE1-4855-814F-083C2C3D3772.jpegthis is where it’s coming from. Any idea what screw or what to do to stop it.
Jhayes780
I wiped it off and observant coming out of that hole when the engine is running it is not burned
99yam40
looks to me that hole is above the fuel bowl level, so fuel should not be that high.
might check the float and needle and seat to see why it is over filling
Jhayes780
Is that the bottom carb? Hard to tell from picture. What happens if you plug it while running? If it runs good time to MacGyver something.
Will try it tomorrow and let you guys know. It looks threaded on the inside.
Jhayes780
Ok so I covered it, it still has a leak at the bottom of the carb. Any idea what it is? Stuck float or needle? Any good articles or step by steps on how to clean this?
Jhayes780
I’m a complete noob when it comes to working on engines. How would I do this
