Stingray 208 water in the engine room
Anders_89
Hello all !
I just whonder if any of u guys have this boat or other model if u get rain water in the engine room? if its raining and i go check the boat for like 3 days there is like 4 liter of water a little more than 1 gallon.
is this normal?
/Anders
airshot
Water runs downhill so any rain getting into the boat from anywhere will probably wind up in the engine room which is probably the lowest point in your hull as it is in most boats
Anders_89
Yes okey, is it bad for the boat to Have water there? I Cant go there every rain day to pump it Out :p
JASinIL2006
Do you keep your boat covered? How much water is getting into the bilge when it rains?
Anders_89
Hi
Yes its covered with ”cockpit cover” But i think Rain is coming in from bimini cover.
If it rains little here and there maybe after 3-4 days 1 gallon of water
Anders_89
Is that the amount of water left after your bilge pump has run?
bilge pump is not running i have power off when im not at boat. i start bilge when i come to the boat sometimes it can pump out water i guess if its more than 1 gallon. if its 1 gallon and under i have to suck it out with a manual pump
airshot
Reposition your pump so it gets more water out, then have it on automatic. With a good battery it can cycle for a long time. On my Islander the pump set at the very lowest point where water accumulated, could pump all but a cup out.
JASinIL2006
If I were in your position, I'd strongly consider getting a second battery and wiring the bilge pump directly to that additional battery. It would make me very nervous to have a boat slipped without an operational bilge pump.
briangcc
If you're having issues with the battery discharging....
1. Find the problem and fix it.
2. Install an onboard battery charger and keep it connected to shore power when you're not at the boat.
Having an inoperable bilge pump while slipped is just asking for trouble.
Anders_89
yes i can relocate it but still i wanna know if its normal with water there or if anything can be broken on the boat if there is water in the bilge? the pump is almost as as far back as it gets but cannot pump if its under 1 gallon water
briangcc
Depending on the intensity of the rain storm, how water tight your cover is, etc, it's entirely possible to get a few gallons of water in.
I had to pull out my FourWinns during a severe storm where I lost sight of the boat and the dock due to the intensity. The birds had happily filled my discharge port with nesting material so the pump wasn't working properly. Several gallons drained due to that event.
IF you're getting water in while its not raining, it's time to start looking for the leak.
Anders_89
Ye i think its rain water cuz when i was out this weekend with no rain there was no water in the bilge for atleast 24h
Anders_89
Anyone know why water zipping from under engine mount?
briangcc
Could be any number of things from rotten mount to waterloggeed foam, to a hull breach to???
Is this boat currently in a slip? If so, given that you're having water issues, I'd be pulling it out for inspection/repair.
What year Stingray are we talking about??
briangcc
Umm not what I was asking.
I see from your other posts that we're discussing a 2014 correct? So roughly 8 yr old boat?
Are you the original owner - I'm wondering if there's a warranty possibility?
Anders_89
Oh sorry lol i fast read. My misstake
Its a 2013 208 :) no its not :/ boat is from us and i bought it in sweden
Maybe its the drain plug?
airshot
Reposition the pump, or get a different pump to get more water out. Mine will take all but a quart out but I do have a slight depression where the water accumulates
Anders_89
hi mate!
yes u see the blue thing in the pic thats the pump. u can see that its mounted on the side and not "flat" far back. dunno why stingray would put it there as it make nosense for me. problem is that is very hard to get ahold of it :(
